Disclaimer, I’m not a pro, but I have used devices since 1977 and am one who pushes computers capacity hard, so have learned much. I also explain science research at a pubic consumption level.
The problem could be location or device related.
If you have a phone that will run on 2.4 or 5 GHz check the signal throughout your space by watching the signal on your phone. I have found that 5GHz devices are great in limited range from your router. The 2.4GHz runs further but is a busier highway.
If you have Panasonic phone or microwave, these interfere with the 2.4GHz range when in use. I personally cannot microwave and use live wifi on my old laptop.
My other devices are optional 5GHz. I cannot use 5GHz in the furthest corner from the router and switch back to 2.4GHz. You can find boosters available but most people find them unsatisfactory in the long run and it adds to the amount of wifi you need to purchase from your supplier. The more wifi devices, the bigger your wifi bill.
I have gone back to hard wire my desk top as I need fast power to run AutoCAD and other heavy system users. we have our TV hard wired too. Much better and I have a crawl space to just run cable easily. If you can do this, being on the leash is not so bad because you go faster and cleaner without wifi concerns. Perhaps talk to your cable or wifi provider about this. I recommend this to apartment dwellers to have the wires run under the baseboard so you are never at the mercy of sharing wifi.
Your device many need a reboot. Check to ensure you are running the latest updates for your device. Keep your machine clean and up to date on all updates. If none of that has worked, take it into a shop and get your wifi card replaced with a compatible upgraded version. If you are comfortable with working with electronics and respect the requirements of working with circuits and electricity, you can do this yourself. There are plenty of videos on line, just watch a few before you start. Some folks are idiots out there trying to cash in. In other videos, each give a tip that none other give.
It takes time to compile the full story but if the problem is important to you , you will persevere. I hope this helps.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
where did you buy the card? When I google the exact specs I am not really finding anything. Is any Intel AC 8265 good or is the (M.2 A Key, M.2 E Key) critical?
par florenceroberts256
