Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'iPad Pro 11" de deuxième génération est sorti en mars 2020 avec les numéros de modèle A2228, A2068, A2230 et A2231.
iPad Pro 11" 2nd Gen boot loop with proximity sensor plugged in.
I replaced the digitizer on my iPad pro and it appeared all went well. I’ve done quite a few iPad’s and there were no surprises. After reassembly it went into a boot loop and at first I blamed the new digitizer. After some process of elimination I tried to turn on with out the proximity sensor and it works perfectly.
Could it simply be that I have damaged the proximity sensor cable and need to replace it?
If replaced, will the face recognition ever work again?
What other features will I not have if I don’t replace it?
Cheers
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire
Hi rumpig70, What came of this? Did you figure it out or end up taking it to someone? Thanks in advance!
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
hello rumpig,
the crash is related to the damage to the tape or the sensor itself (which is a triple sensor: proximity, flooding with dots and interpretation). If the sensor wasn't flooded with water when the screen was broken, chances are you broke it while removing the screen. The sensor assembly itself can be replaced, but the Face ID function will be lost. The solution is repair. If you have enough experience do it yourself. If not, send to a really good repair shop. Experience in such repairs is crucial. (Nobody who has not done dozens of such repairs before will do it well). Good luck, I keep my fingers crossed.
  • regards,
Indice 1
Ajouter une réponse
rumpig70 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 21
Total : 1,538
