Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Lenovo Yoga 2 13" peut passer du mode ordinateur portable au mode tablette, tente ou chevalet grâce à ses charnières latérales. Il est sorti en janvier 2014.
Does this laptop have only soldered RAM? Is it not upgradable?
I’ve also just pulled the bottom cover off to take a look and it seems there may be some room for a secondary SSD/HDD in addition to the included M.2 drive.
Am I understanding this correctly? I don’t want to futz around with it much before knowing what’s possible.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@printedwaffles the RAM cannot be upgraded. The Yoga 2 13 has 2 slots: 1 m.2 (that is now used for your SSD) and another connector for a 2.5"  storage device. For some models this is a normal SATA connector, but for most it is a very rare SFF-8784 connector that only connects to the 5mm WD HDD. Found these for part numbers ZIVY0 HDD Bracket : 90205123
ZIVY0 HDD Cable WD : 90205124
Indice 2
2 commentaires:
Thank you. I was a bit confused after opening it up. There seemed to be some unused space that could potentially fit a laptop drive, but I didn't see a SATA style connector around.
Thanks for the part numbers! I'll be exploring this further.
Too bad about the RAM. Silly Lenovo.
par
Man, looking these things over, it seems like a ridiculously obscure way to go about adding storage space. It might end up cheaper just getting a larger m.2, and certainly less time consuming.
Again... Silly Lenovo.
par
Ajouter une réponse
Alberto Einsteino sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 19
Total : 518
