Freezer is cold but the refrigerator is not cooling
We are having the same problem. Freezer is cold, refrigerator not cooling Model # KSRS25QDL01
Vickie, you can check the condenser coils underneath by removing the grill at bottom in the front. Run the vacuum or brush to remove dust. Always unplug refrigerator first!
Then pull out the refrigerator, remove the access panel and clean. Was it dirty? If so the compressor and condenser got hot. Are both fans are running when the compressor is running? Remove the screws pull the back panel off and you’ll see the evaporator coil‘s If they are covered in ice then you have a defrost issue and the heater and tstat are under that ice. If no ice then the issue is in the sealed system and only a certified licensed refrigeration technician can do the repairs.
Vickie, the condenser and evaporator are no long available for that model. If the coils had a leak you’d have a hard time getting that repaired. Just thought you’d want to know.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 632
