No picture but I have sound
Went to bed last night tv was fine, got up this morning tv picture is black but I have perfect sound?
@sheffwife we need your TV's complete model number. You also should let us know what you have already checked (Tried all different Video input sources etc.) You also want to try to unplug the TV and unplug all accessories connected to it. Then hold the power button depressed for something like a minute or two. After that plug one video source, preferably local like game console, DVD/BR player etc. and see if you now get video. If not the check in a darkened room, shine a flashlight at an angle against the TV screen (TV must be on and you have to have sounds etc.). If you can make out shapes, silhouettes etc., then you know that this is a backlight issues. If not then there is the possibility that this is a main board, power board, T-con board or even the display panel. We would need to see your boards etc. to make any kind of further repair suggestion.
Model LC-4OUG7252K
Tried to reset, but now sound gone as well!
Any further help/advice would be good?
Thanks
@Paul Casey How did you attempt to reset? What did you check before?
Led light could be blown and shorting other led off or t-con board may be damaged in an LCD TV
the power light is on, the picture is dark
I figured it out! I did some research and found out it was the T-con board that was faulty. You can do some light research to find out where your t-con board is located on your tv but generally it is the board with 2 thick ribbon cables going to the display. With my Sharp Tv (model: LC-46D85U) I was able to find the correct t-con board online by opening up the tv and trying to find a model number for your t-con board (mine was CPWBX4023TPXA ) I was able to find some on ebay for 60 to 100 CAD (45 - 80 USD). I think replacing the t-con board will fix your issue as I have not yet purchased mine from ebay yet so I cannot give a straight answer. Hope this helps!
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 137
Total : 15,168
1 commentaire
Buen día, tengo el mismo problema. LCD MODEL 50BL2EA
par Marco Juarez
