Aller au contenu principal
Apple logo flashes briefly when plugged in
I have a Nano that does not do anything when not plugged in, and when I plug it into the computer the Apple logo comes up very briefly (<1 second) before the screen goes black. It doesn't just do this once, though, it continues to flash on and off, as if it is trying to start up, but can't. I imagine that if it were a battery issue it would still work when plugged in. Is this a logic board or perhaps a connector issue? As of right now, my plan is to open it up and clean all of the logic board contacts with isopropyl alcohol and see if that helps.
Update
Simply cleaning the dock connector did not change anything. It looks like this Nano is going under the knife.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
3 Réponses
Solution retenue
Just as I thought, after opening the iPod up and cleaning all the contacts with alcohol, it turned on and the computer recognized it. Hooray! Except for the fact that I broke the click wheel ZIF connector. Looks like I have more work to do if I really want to use this iPod...
Indice 1
did you restored it ?
Indice 0
1 commentaire:
How do you suggest I restore an iPod that can't turn on and won't connect to a computer?
par
connect your ipod to PC then press and hold home button & play/pause button it will goes disk mode then retore with itunes.............enjoy
Indice 0
Ajouter une réponse
David Hodson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 18
Total : 6,042
