Can't reseat motherboard connector after battery replaced
I was following these instructions Remplacement de la batterie de l'iPhone SE and nowhere did it say to be careful not to remove the connector that could be confused with a screen connector as I did. Now, no matter what I do I can’t align and reconnect it. How do I reseat it as its likely a bit twisted due to cable tension and also off centre. These things are so tiny. Its the connector centre left above the lower left screw. What tool and technique would help?
2 commentaires
If the battery isn’t stick to the backhousing already , I usually first put the battery connector in and then position the battery in its place at the backhousing .
par Leslie Leslie
The issue is alignment of the connector. Its not a battery connector its from the motherboard.
par Rusty
