Aller au contenu principal
The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
Questions au sujet de 17 Voir tout
My phone thinks the down volume button is pressed
I own a xiaomi red mi note 8.
I was listening to music normal and it started lowering the volume by itself. I tried to get the volume higher a few times (pressing the up volume button or using the screen) but it kept going all the way down.
So i turned it off and cleaned it a little bit just in case something was bothering the button from the outside, or if the system was stuck. Then when I opened it and it still thought that the down button was pressed so it sent me to fast boot. Somehow I managed to boot it properly and now it seems to be okay, but i think it will happen again.
Is it a hardware or a software error? if there’s nothing I can do about it I might need to buy a new one.
Répondre à cette question J'ai le même problème
Indice 6
2 commentaires
This is what's happening to my phone now. It's Redmi note 7 btw. :/
I start to think that I need to switch to another brand. Xiaomi sucks :’(
par
It’s the second time this happens to me. The first it just went away in a matter of hours but now it’s really irritating me. It won’t go away. The Google Assistant fix doesn’t work for me either, ugh!!!! I can’t live without music and videos so this is annoying
par
Ajouter un commentaire
12 Réponses
Réponse la plus utile
I know it's late for answer but i was having the same issue and i hit sound up/down button to table 2-3 times and it fixed :D
Indice 60
74 commentaires:
No way that worked for me too lol. Made an Account Just to thank you. :)
par
Lol, the same . Why does it work xd??
par
wow mate, thanks for your answer, it literally solved the problem
par
Man, it really worked. I almost gave up and buy another phone. Thanks a lot
par
Yeah, that worked for me too. Even my phone entered fast boot mode multiple times and the volume went all the way down to zero on its own.
I thought it was a software bug and soon had made my mind to install custom rom or so. Hitting the button (gently) literally solved the problem! Thanks!
par
Voir 69 commentaires en plus
Hello ! I had the same problem, it seems like a software problem because it disappear after a time …
Indice 4
2 commentaires:
I had the same mobile but different issue. It was fingerprint issue so I replaced it with Fingerprint cable, then it starting working as normal.
https://www.xfurbish.com/mobile-fingerpr...
par
I don't think it's a software problem. I was having the same issue, and I managed to turn my phone off, but it would go into fastboot mode, which is triggered by holding the volume down + power. So this makes me think it is a hardware issue. I did what Mustafa commented and now my phone is working.
par
For people who has this issue and hitting table doesn't work, i found an app named 'buttons remapper & combinatin' by 'Irishin'. You should download it, then give permission and then click + button in app, choose the button with the problem for me it is 'volume +', choose 'do nothing' for the action and enable 'block system action'. From now on my volume up button is not sensing anything. For increasing volume , i will use volume down button to see the volume window on screen then will use touchscreen to turn the volume on.
Indice 4
2 commentaires:
Hey there 👋
Made an account just to say — Thank you. This bug has been following me for nearly a year now. No idea why it started, but honestly, this little mf annoyed me quite a lot, and as I can see, not only me 👀
Anyways, glad I haven't stopped searching for a solution 🤝
par
Thank you so much for this solution! Banged the volume button several times already, but this one you suggested is what worked!
Just made an account, too to let you know how grateful I am! Thank you so much!
par
I had the problem there i smacked the phone on my bed and i was hitting my phone without any reason then i found it was a software problem. After knowing it i started searching for a genuine solution but i didn’t find any but after a lot of reaserch i just solved my problem by reboot.
Redmi volume button problem solution
Hope this will help you also
Indice 4
I had the same thing. Just smash the volume button it 3 times at the table and it will be fixed
Indice 1
1 commentaire:
Worked perfectly
par
This isn't a software bug (for my case). I found out that even the slightest touch to the volume button will trigger the problem where the volume down is stuck
Indice 1
I got a xiaomi redmi note 8. And today I experienced the same thing and it started when I was playing league of legends: wild rift and it becomes a hindrance in my game as it blocks the buttons I use to play the game. If you want a visualization; the volume always appear in the screen, every second so it doesn't go away. I tried restarting the device but the options to "airplane mode";"silent mode";"restart";"shutdown" don't appear. So, I long press and the device shuts down. Then when I try to open it go to Fast Boot. I tried doing what Mustafa said and in addition tried to clean the earphone slot with cotton buds with 99% alcohol. After that my phone goes back to normal. (I already have pried open the back of my device to try to fix the buttons itself but don't know how to get into the buttons itself.) Hope this helps the others before they pry open their device.
Indice 0
In my mi phone volume button automatically increasing when I simply touch on volume button It sensing like fingerprint
Indice 0
My phone volem up and down automatic why
Indice 0
the same thing happened to me while I was playing League of Legends: Wild Rift, and it started blocking the buttons I need to play the game, which is a hassle. If you desire a visual representation, same as contador de palabras the volume will constantly show on the screen, updating every second. I attempted to reset the gadget, but the "aeroplane mode" and "quiet mode"
Indice 0
I have the same thing on my xiaomi redmi note 8 pro and because of this issue, i cannot exit the Fastboot mode. I have to know how to fix this problem else i cant use my phone. Did you figure out how to solve it?
Indice 0
2 commentaires:
lightly hit it against a hard surface
par
hit the volume up and down buttons 3-4 times. I read this fix from another comment in this thread and it worked for me. Havent encountered the same issue since a month ago. I use xiaomi 10T
par
Mine right now has that same concern and maybe it's my volume buttons that has the problem because eve if I slightly touch it or just barely, it turns up. Now I'm looking how to disable this button or find who can repair this
Indice 0
1 commentaire:
Hi, have you tried the following suggestion? it worked for me for 2 xiaomis:
<<I know it's late for answer but i was having the same issue and i hit sound up/down button to table 2-3 times and it fixed :D>>
par
Ajouter une réponse
whyyy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 92
7 derniers jours : 622
30 derniers jours : 2,568
Total : 38,891
