Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations de réparation et d'entretien pour les disques de stockage externes Western Digital Elements.
After "copy" "paste" the hardrive does not working anymore
I just bought a hardrive. I plugged it, copy paste some file. The transfer didn’t finish. It gives an error and now it does not work at all. (see an example)
Notice : I’ve already done some scan and try to find the hardrive through the windows built-in options or with another program called “AOMEI Partition Assistant” but it does not appear.
I also used wd elements scan program. It cannot do anything because of there are too much blocks error.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
8 commentaires
Hi @kevin07
if you had tested with another computer and it is also having the same issues, e.g. read / write issues, try sending back for a exchange / repair
par Partager
The seller does not respond when I try to contact him.
par Partager
@kevin07 Whered uou buy it from? if its from ebay, give them a call, they can help you
par Partager
No that was from aliexpress.
par Partager
@kevin07 oh. I’m not entirely sure how that would go down then, as Ive never bought anything from aliexpress
par Partager
Voir 3 commentaires en plus
Ajouter un commentaire
3 Réponses
Solution retenue
I know this is not an immediate solution but for future choices.
These name branded external drives are the worst possible choice. Always, always purchase a SEPERATE case/controller and hard drive. Again, why? Often the branded ones have the drive’s circuit board and the USB port imbedded in the same circuit board. If that circuit screws up you are often lost. The component solution (like a good hi-fi sound systems) allows you to easily take the drive out, if the USB part goes bad, and recover your software in another system or case.  If the drive dies replace it or upgrade to SSD or larger capacity. A no brainer!
Indice 2
I had the same issue with a brand new 2T external hard drive, in my case the drive would systematically stop working when it reached around 750Gb data storage. I could still format it with gparted and it would be usable again but the problem is still there and I haven't found a fix to this fault yet, so I'm left with less than half storage capability. That said, worst case scenario you can't get a refund/replacement, you could try doing some tests with utilities like smartmontools(cross-platform) and badblocks(GNU/Linux) and hopefully solve it
Update (01/12/2021)
UPDATE: After disassembing, connecting the disk to the pc through SATA and wiping it (zero-fill,1 pass) the problem was gone, all disk space usable, no more r/w errors - along with the terrific slowdowns and frequent hangs - occurred during file transfer. So I put the drive back in its USB enclosure, formatted it and tested again, still works fine, so I suppose one can replicate this without taking the disk apart. From what I understand, reinitializing the hard drive allows the identification and correction of damaged sectors; sure it takes a while, but mkfs utility did the trick for me. On Windows there's a variety of free tools (most of them included in hirencd) to diagnose/fix hard drives presenting software-corruption symptoms
Indice 1
2 commentaires:
Hi @simone_i
share more on where you get the hard disk and the model of it
par Partager
I ordered it from a local store here in Italy, model is Seagate expansion SRD0NF1. Still havent't tried testing the hard drive only without the usb controller, I hardly doubt that could be the cause, a manufacturing defect is more likely IMO. However I'll do some more tests when I manage to free up enough space to backup the data I have on it
par Partager
A “block error" means the hard drive is dying.
Indice 0
2 commentaires:
That was my first use of this hardrive. It can't be.
par Partager
Hi @kevin07
well it is possible, i suggest to file a dispute, sometimes either seller is dishonest or during transit on your package, it get damaged.
par Partager
Ajouter une réponse
Kevin sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 1,299
