Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Seconde génération d'iPhone. Modèle A1241 / capacité de 8 ou 16 Go / dos en plastique noir ou blanc. Sa réparation est plus simple que celle du premier iPhone. Nécessite des tournevis, un outil pour ouvrir et des ventouses.
I broke the pcb near the do not remove sticker
Hi there! So I’m sure you can tell I’m a noob to repairing stuff after this. So, I was taking apart my iPhone 3G, and got almost through taking the screws out. Once I took all of the visible ones out, I proceeded to pull out the PCB. I didn’t remove the sticker that says do not remove :(, so I cracked the PCB right near the screw. What does this do? I’m kinda worried, but I don’t need this phone for cellular, I need it for CoD WaW Zombies haha.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Difficult to assess the damage without a picture of the board. If you just broke the screw hole, you might be okay. But if your crack goes through one of the many lines (also called traces) that you can see on the board you will most likely have broken something on the board since that connection is gone.
Best way to check is to re-assemble the phone and test it again.
Indice 1
1 commentaire:
yes, I did cack one of the traces, I've been examining it, and it appears its just where the phone makes contact with the silver rim for cellular connectivity as there's only 2 traces that go there. I thankfully didn't get the battery connectors there. Thanks so much for your help!
par
Ajouter une réponse
Quinn Bellmore sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 17
Total : 380
