Home button not working correctly after replacing battery
After I replaced my battery my home button is acting very strange. Touch ID is fine, but the click is very strange now and then. Sometimes it works perfectly fine and other times its freaking out. When I hold it for example it keeps clicking, when it’s supposed to click just once. Does anyone have an idea how to solve it?
I’ve already tried to loosen the screws, checked the cable for tears, none visable. Hard reset doesn’t work either..
Thanks in advance.
No one? Please there must be a solution.
par Robin
Hi Robin,
There might be a loose an intermittent connection from your touch ID to the display assembly, or a dodgy connection between the screen assembly and the logic board. Have you tried taking it apart again and disconnect and reconnect all the cable connections?
Sometimes where there is a misaligned connection the buttons/screens etc work intermittently.
par honakrisi
Hey there,
I just took everything apart again, checked the the cable from the button to the screen and from the screen to the motherboard. That didn't solve the problem, there must be a tear internally in the cable from the screen to the motherboard is my guess. Or does anyone have another idea?
par Robin
Hi Robin, The button is mounted with a bracket behind it. From a repair a few years ago i remember something with the pressure of this bracket. I'm not sure because i don't use iPhone's myself and only assisted with the repair back then but you could give it a go and change the tightness of the screws to see if you notice a difference in the mechanics of the button.
par gmantunt
Hey Gmantunt, I've tried to loosen te screws but that didn't help either :(. I've ordered a new screen and a taptic engine just to be sure. Gonna replace them both tommorow, I'll let you guys know if it helps.
par Robin
Afficher 1 commentaire en plus
