Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le JVC KW-V820BT est un autoradio avec écran de 6,8 pouces conçu pour être installé dans le tableau de bord d'un véhicule. L'appareil est équipé d'une vitre tactile et peut lire des sources audio variées. Il peut se connecter simultanément à plusieurs téléphones et permet d'utiliser certaines applications.
Help ...My JVC KW-V820BT stuck with firmware upgrade
My JVC KW-V820BT stuck with firmware upgrade and keeps restarting and not opening the main screen.
How can I reset it back to the original firmware or reset it?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Check on JVC's website for instructions on how to update the firmware. Also check popular car audio forums to see if this is a known issue with this model. There may be instructions on what to do when the update fails or how to revert back to an earlier version of the firmware. There might also be instructions - on JVC's website or online car audio forums - on how to hard reset the radio which could clear up the stuck firmware. If nothing seems to work, it might need a trip to an authorized JVC repair shop.
Indice 1
One guy on a Reddit thread had the same issue with a KW-V830BT radio and got a suggestion from someone who found people who had successfully gotten around the problem.
JVC KW-V830BT Bootlooping after firmware upgrade attempt : r/CarAV
Here's the relevant part.
And on a different thread, the suggestions got a little more specific.
Tip: JVC Arsenal KW-V820BT update to 2.6 firmware : r/CarPlay
And a bit later in the same thread:
And one more:
This JVC failed it's USB update halfway through. Anyone know of a hard reset procedure or is it toast? I've tried everything I can think of or find online. Just keeps boot looping and going to this screen. : r/AndroidAuto
So it appears the solution to this is to use a small flash drive, definitely less than 32GB, but possibly smaller than 4GB, or partition an existing drive to something like 16GB and make sure it's formatted to FAT32.
Give that a try then come on back and let us know what you find. Good luck!
Indice 0
Ajouter une réponse
Galal Eltahan sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 37
Total : 434
