Aller au contenu principal
L'Apple iPhone 5s fut annoncé le 10 septembre 2013. La réparation de ce modèle est très similaire aux modèles précédents et requiert des tournevis ainsi que des outils pour faire levier. Disponible en version GSM ou CDMA, 16/32/64 Go de stockage et en argent, doré ou gris sidéral.
32 questions Voir tout
Detached screw mounts - can I re-attach them
Hi …. I repaired my wife’s iPhone 5S and in the process of doing so a couple of the ‘mounting/receiving luggs’ for the plate that sits over the screen connectors detached themselves from the plate they were adhered to (see images) ….. is there a recommended method/adhesive I can use to re-attached them ? The plate is in place an held by two screws at the top currently
Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
If I’m not mistaken those are standoff points that are soldered directly to the board which would require micro soldering tools to fix but you should be fine to leave them as they are. Just make sure you’ve retrieved any loose bits to ensure no damage is done after the repair is completed. I’ve had lots of phones come in without the shields or screws present and they work perfectly fine. They’re just there to make sure the connects don’t disconnect on impact but I have yet to see them disconnect from an impact.
Indice 1
Ajouter une réponse
Keith Joslyn sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 28
