Aller au contenu principal
The Dell Inspiron 11-3147 is an 11" laptop-and-tablet hybrid device. The screen can fold onto its back to allow for handheld usage. It was manufactured in August 2015 by Dell.
13 questions Voir tout
Hinge problem: Why does the hinge get stuck
My Dell Inspiron 11-3147 fell on the floor and as a result of the drop, and one of the hinges will not rotalte fully any longer. I cannot close the laptop, neit Iher can I fold it like a tablet. That hinge will only rotate a little in both directions, then it gets stuck. I tried to force it a ittle, but it won't turn/rotate any further. I did not force it too much so that I won't break it. Does it have something inside of it that can cause it to get stuck? Some sort of mechanism?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
  1. Unplug charger.
  2. Remove the screws on bottom cover
  3. Remove battery
  4. Unplug & loosen the hard drive cable. ...
  5. Unplug & loosen the antenna cables.
  6. Remove the bracket screws. ...
  7. Remove the tape. ...
  8. Open the laptop flat. ...
  9. Use fingers to pry apart and separate back cover from screen.
This video should help :
https://www.parts-people.com/blog/2018/0...
Indice 1
Ajouter une réponse
Mike Turk sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 33
Total : 1,352
