Aller au contenu principal
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
Questions au sujet de 77 Voir tout
How to change key ignition switch
how to change key ignition switch
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Solution retenue
Check the attached image, it will give you a breakdown as to where the parts are that you need to look at. I could rewrite the instructions but you may benefit from the excerpt of the manual.
Update
Seems like my images disappeared :-) Here is the description:
Disconnect the negative battery cable. If equipped with an air bag, wait at least 90 seconds before working on the vehicle.
CAUTION
Some models covered by this guidemay be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Chassis Electrical .
Remove the lower steering column cover. Unfasten the ignition switch connector under the instrument panel.
Remove the screws which secure the upper and lower halves of the steering column cover.
Turn the lock cylinder to the ACC position with the ignition key.
Push the lock cylinder stop in with a small, round object (cotter pin, punch, etc.).
On some vehicles, it may be necessary to remove the steering wheel and combination switch first.
Withdraw the lock cylinder from the lock housing while depressing the stop tab.
To remove the ignition switch, unfasten its securing screws and withdraw the switch from the lock housing.
To install:
Align the locking cam with the hole in the ignition switch and insert the switch into the lock housing.
Secure the switch with its screw(s).
Make sure both the lock cylinder and column lock are in the ACC position. Slide the cylinder into the lock housing until the stop tab engages the hole in the lock.
Install the steering column covers.
Connect the ignition switch wiring.
Connect the negative battery cable. from here I also suggest to check this site and look for a posting by "Fluffy", it has some really good images that will show you how to do it. Hope this helps, good luck.
Indice 3
1 commentaire:
I have same problem with my 95 camry
I baught a new ignition switch and a new ignition cylinder install it turn on the key every thing works except my steering wheel locked up while the ignition is ON!
Any one got any idea whats goin on or the issue is????
par
Ajouter une réponse
antweezie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 74
Total : 29,834
