Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation et connaissances techniques pour le Xiaomi Mi Mix 2, sorti en 2017.
How can I check whether my charging port is broken? (Xiaomi Mi Mix 2)
Hello there!
I have a problem with my current Xiaomi Mi Mix 2. I does not charge. I suspect that the charging port is the cause of the problem since I have had problems with it before.
My question is how can I check whether the charging port is really broken or if the problem is somewhere else.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
The easiest way would be to buy a little USB Amp/Volt Meter and plug it into the wall and then your charger cable into that and it will let you know if the charger is drawing amps or not. If not it’s most likely in need of being replaced.
The meters are less than £5 if you look around…
Indice 1
Ajouter une réponse
BugReport Plon sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 602
