Nintendo Switch Lite ZL not responding
So the ZL button on my son’s switch lite has stopped working. I have opened it up and cleaned out the button contacts with alcohol to make sure no dust or debris was in the way. I have pulled the ‘left’ control board to see if there was any noticeable damage and cannot find any visually. I’ve reseated the ribbon cables and cleaned out any ‘gunk’ I found again with alc. I’ve also switched the button ‘pad’ from the ZR that makes contact with the board to the ZL and still nothing is working. I am about to just order a replacement left board because I can’t think of anything else that would case this to stop registering. Everything else works flawlessly on the device outside this one button. What can else could cause this?
does the button actuate at all when its disassembled? like can u depress it and it clicks when it is taken apart?
par Logixal
Yes it appears to be fully intact and operating properly mechanically but for some reason it won’t register as a keystroke.
par Mike Hanskat
