Aller au contenu principal
Mis sur le marché le 26 octobre 2018. Modèles A1984, A2105, A2106, A2108. Disponible avec GSM ou CDMA / eSIM, nano-SIM ou dual-SIM / 64, 256 ou 512 Go / Noir, blanc, bleu, jaune, corail ou rouge. (Se prononce "iPhone 10 R".)
20 questions Voir tout
No image, diode readings and connector seem ok
Customer tried to change the screen after a fall, tried with my replacement parts, still no image, connector seems ok, diode mode readings seem ok. checked for LSD, no evidence. Phone boots ok, everything works apart from screen.
What could it be?
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires:
We will need some more info. Have you checked it is not the backlight circuit? Depending on USB restrictions will your PC recognise it? What is the reading on the USB ammeter?
par
Phone works perfectly, apart from the screen :)
par
Ajouter un commentaire
1 Réponse
hello Marco,
turn on thinking :-) if the phone works and you are sure of it. In addition, the measurements also seem okay to you, think more. Every electronics engineer knows that measurement in the diode mode does not guarantee the correct signal in terms of its power and value. If you are sure that the screen is working (I advise you to check it again), the screen is probably not efficientlly powered or has 0V from the motherboard. This is an electrical device - powered by electricity, not resistance. This is a very common mistake of beginners.
  • fingers crossing, regards
Indice 0
Ajouter une réponse
Marco Reibaldi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 136
