Where can I get a control board for my HE550HUD-B31/JM/72104002 Panel
I have a bricked Hisense 55” 4K Tv, but the panel should be fine.
I want to use said panel as a screen for my Mac, but i could’nt find a control board anywhere.
Can you get a control board for my panel?
Can you just use a similar control board instead?
The whole back
I guess the display controler
its model number
I guess the power supply
its model number
another number on this board
I guess the board which handles all the inputs
its model number
Maybe the speaker controler
the model/serial number of the TV
again but on the panel it self
I hope this is enough, if not just ask again
12 commentaires
@simontt post a good picture of the label on the back of the LCD panel. Let's see the make and model of it so we can try and help you to find a driver board.Ajout d'images à une question existante
Unless of course you are referring to the main board. For that we would need to see that board. Hisense uses a bit of a hodge podge of parts so we need the numbers of it.
par oldturkey03
@oldturkey03 Hy I updated it as you said but I guess I have to tag you for you to get a notification so this is it
par Simon Nattrodt
@simontt lets see what we can find for you
par oldturkey03
The board you referred to as the display controller is actually your LED drive board. Your main board is a RSAG7.820.5857 and seems to be used in LOEWE TV ART40 as well
Since you call it bricked, what exactly is your TV doing? Where in the World is the TV located? Just to make sure we got the right supply chain :-)
par oldturkey03
@oldturkey03 the TV doesn't do anything when you press the Power button, no led no nothing, it is truly bricked. It is in this state since a storm, ahead of it the power strip, it was connect to, was unplugged, after the storm, when the entire power strip was reconnected, it just died.
It is in Germany
par Simon Nattrodt
Voir 7 commentaires en plus
