3 seconds sequence ghosting
Sony Bravia 42" LCD TV KD-49x7000D
Hi I have been having an issue with my TV as you can see on the pictures the image is fine for 3 seconds then has a ghosting effect for 3 seconds then back to normal.
This just goes on and on.. I thought it was a flat cable issue on the T-Con PCB but while moving the cable gently around there is no effect to the issue so my guess is a IC chip or Quartz that is defected but Id like a second opinion please
Thank you
4 commentaires
@mishane what does your onboard menu look like? Does it do the same thing or is it clear? What exact model is your TV?
par oldturkey03
@oldturkey03 Yes it does the same thing on the onboard menu.
This is the model Sony Bravia 42" LCD TV KD-49x7000D
par Mishane Arithoppah
@mishane i also had the same model with the same issue which i have only used for 1 yr and 3 months. i've took it to the service center, the panel is goneeee
par NIBINSHA NAZAR
I've had the same problem on my Sony 42" and it started a few days ago. I'm not technical though so advice to "check the board" means little to me.
par Raymond Pearce
