Aller au contenu principal
Annoncé le 13 octobre et sorti le 23 octobre, le smartphone vedette 2020 d'Apple est doté d'un écran OLED de 6,1 pouces, d'une caméra arrière à triple objectif avec LiDAR et de la 5G. Il succède à l'iPhone 11 Pro.
Questions au sujet de 55 Voir tout
Is there a repair guide for replacing the glass back of the 12 Pro?
Is there a DIY repair for the glass back of the iPhone 12 Pro? I see parts being sold online but I do not see a repair guide on this website.
Répondre à cette question J'ai le même problème
Indice 7
Ajouter un commentaire
1 Réponse
Réponse la plus utile
There will likely be one in the future on iFixit, however it's not really an easy process at the moment so not practical, especially for the DIY repairers.
*EDIT: Just had a quick look and there is a guide that involves the laser machine here
I'm lucky enough to work with a $4000 laser machine that is used to laser off the adhesive between the glass and frame so it can be broken and chipped off slowly. We also have to use specific diagrams when lasering or else risk lasering an antenna from the device. Then the replacement glass is glued on and bonded down.
If you don’t have an expensive laser removing all of the old glass and adhesive is really tricky o do cleanly and if a small piece of glass is left there when the replacement glass is put on, it’ll all shatter and all be for nothing. It’s a pain because of the way Apple has decided to construct the device, but I’d recommend taking it in to a repair shop for this repair as they can maybe do it same day and with all the correct equipment, but without charging as much as Apple might.
Indice 3
Ajouter une réponse
michrobi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 89
Total : 1,798
