Aller au contenu principal
Ordinateur portable Toshiba Satellite C55-A5100 de 15,6 pouces avec un processeur Intel Core i3 — 3120M cadencé à 2,5 GHz, avec 6 Go de RAM, 750 Go de disque dur et un lecteur DVD-RW.
7 questions Voir tout
Toshiba Laptop no signs of life ( CMOS Battery )
Hello! I made little scraches under cmos battery by mistake and after i put back cmos battery Toshiba Satellite laptop doesn’t start. There is no power ( its connected to power ), doesn’t show battery or no other light. Totally no signs of life. I want to ask the problem is on motherboard or another thing? How can i check and proceed? Please help me, thanks!
Update (08/09/2021)
Here: https://ibb.co/Fn52vm8
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Réponse la plus utile
If the laptop worked fine BEFORE you scratched (?) the CMOS battery then just replace the battery. The CMOS battery is how the laptop keeps all the settings for the BIOS/UEFI - how the computer knows what to do.
Let us know how it goes. These “CR2032” batteries are cheap and can be purchased just about anywhere.
Indice 1
2 commentaires:
I understand but pins under the cmos battery doesn’t hold battery itself.. I search in google and CMOS battery cannot cause no booting ot no power, but thanks anyway i will try!
par
@FortniteshopBG
A corrupted BIOS can cause no booting and no lights. I've dealt with that problem at least 4 or 5 times but with the CMOS battery removed usually something will happen as that will cause the BIOS to reset factory default.
par
Can you provide photos of the affected area?
Indice 1
1 commentaire:
Looks like damaged trace(s), which can be repaired using solder or jumper wire. Here's a video illustrating the basic idea: https://www.youtube.com/watch?v=qLf1gBg7...
par
If your Toshiba laptop shows no signs of life, a dead CMOS battery could be the culprit. The CMOS battery powers the laptop's BIOS settings and clock. Try the following steps:
1. Check the power cord: Ensure it's securely plugged into both the laptop and the wall outlet.
2. Power button: Press the power button for 30 seconds to discharge any residual power.
3. CMOS battery: Locate the CMOS battery (usually a small round battery, like a watch battery, located on the motherboard). Remove it for 30 minutes to an hour to reset the BIOS.
4. Reinstall the CMOS battery: Put the battery back in its original position.
5. Try to power on: Press the power button to see if the laptop turns on.
If the laptop still doesn't show any signs of life, it's possible that the issue is more serious and requires professional attention. You may want to contact Toshiba support or a authorized repair center for further assistance.
Keep in mind that if the laptop has been inactive for an extended period, the main battery may also be drained. Try charging it for a few hours before attempting to turn it on.
Let me know if you need more help!
Indice 0
Ajouter une réponse
FortniteshopBG sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 983
