Une version plus abordable et purement portable de la console de jeu Nintendo Switch, avec des manettes Joy-Con intégrées et un écran légèrement plus petit. Sortie le 20 septembre 2019.
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
3 commentaires:
Can you explain a bit more to what you are reffering to?
Oh like the head is stripped? If you were able to get a little bit of it out then a pair of fine point pliers could grip on it enough to get a couple.of turns out.
Also sometime placing an elastic in the head of the screw before putting your screwdriver can help get some grip.
If you have bigger bits you could try to see if one fits with the new shape made by stripping it.
par Innovatrix Repairs
@innovatrix I was opening up my switch but I can’t get a screw out it look like it is damaged and I have no idea how to remove it
par Arjun Manikandan
I hope this helps
