LG Front-Loaded Washing Machine Code: OE . Spins but doesn't drain.
LG Washing Machine Front-Load (DirectDrive + 2-in-1 dryer) woudln’t drain often and most of the time would just throw OE error code.
Other day, when I set it on spin cycle only, it would literally reach 1000RPM but drain wouldn’t even turn on, even though the inside is full of water and the water was splashing left to right inside.
Also, on dry mode, clothes would just be soaking in water.
Usually, on washing mode, it drains fine, but when it reaches the spin cycle, it just stutters and does nothing (Balance is good, already been testing with different clothes, towels, low loads, high loads).
And it just works by the day, sometimes it would drain (barely), other time it would seem that it’s not even trying to turn on the pump… Cause pump works, you can hear it draining and stuff, when it drains, it drains, but for some reason it just wont turn it on.
What I tried :
- Inspecting/Clearing items or debris from drum silicone thing near door.
- Inspecting/Clearing out the bottom drain (a.k.a emergency drain) and cleaning it.
- Inspecting pump from the back of the machine (haven’t found anything inside the tubes)
- Inspecting the drain hose (all good)
Also, when the machine tub is spinning, it makes some sort of noise, like theres friction with something. Couldn’t find anything, but it just sounds like it has friction with something when it spins any time. I would describe the sound, as if you would put the towel under the washing machine tub and the tub would friction with it every spin.
I’ve inspected the tub and I could’’t see anything through the holes, but maybe there’s something there and if there is, I have no Idea how I would need to clean there…?
Any Ideas? Could it be that some sensors are failing?
Hi @xprsiv,
What is the model number of the washer?
par jayeff
