How to change the front glass only.
How do I change just the front glass screen? Any help
I have not done this myself.
https://www.youtube.com/watch?v=H6ZM_arR...
Just a further note of caution on this;
When cutting through the adhesive holding the glass it is REALLY IMPORTANT to only insert the tool up to approx 6mm under the edge of the glass. Sliding it in further can damage the digitizer.
At the long edges the adhesive under the glass is only approx 2-3mm from the edge. On the short edges it is wider, maybe 5-6mm from the edge. Once the adhesive is hot it is quite easy to cut with a plastic guitar pick but do not slide it in too far. I used a little alcohol on a cotton bud to lubricate the guitar pick and help it slide.
Once the glass is off, the access to the remaining parts is quite straightforward.
You will need to source a replacement adhesive strip which can be found on internet sellers.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 116
