Aller au contenu principal
Informations sur la réparation du Xiaomi Redmi Note 8T, un smartphone sorti en novembre 2019. Ce téléphone porte le numéro de modèle M1908C3XG.
xiaomi redmi 9t won't turn on
My phone battery got drained this morning, and even if I’ve already charged my device, it won’t turn on. I’ve also done many google solutions. Can someone help me fix my device? :((
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires:
Hi,
Check if you can get into the recovery mode for the phone.
Here’s a link that shows how to do this.
If you can’t get into the Recovery menus it may be a hardware problem.
If you can get into the Recovery menus DO NOT select factory reset/wipe data as this will erase all your data and downloaded apps in the phone.
par
I have the exact same problem. It is crazy that Redmi still hasn't properly resolved this issue after several models showing hundreds of the same model. There should be a flipping class-action lawsuit against them!
par
I had the same problem, I fit it getting alcohol on the motherboard
par
Ajouter un commentaire
2 Réponses
You most visit the warranty shop and let them fix the phone ar any mobile center, when you fix it you mustn't charge the phone with copy charger just the original
Indice 0
Kenapa hp saya tidak bisa menyala lagi apakah IC yang kena
Indice 0
Ajouter une réponse
zyrhelle mae balinang sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 17
Total : 2,385
