How long does battery calibration take?
Last week I replaced my iPhone 8 Plus battery with an iFixit replacement. I followed the recommended steps for calibrating it, and kept cycling the battery full to empty and back when using the phone for the next couple of days, but it consistently shuts off at around 45-50% battery. It does last longer than the old exhausted Apple battery did, so it seems the capacity is fine, it’s just the calibration that’s off. Is this something that will fix itself with usage? Thanks.
I have the exact same problem. I followed the calibration steps. But the phone is still shutting down at 40-50% and charging and decharging in jumps as reported in Apple battery settings. Did it resolve itself @edbennett ? Did you find any other solutions?
(Also using iPhone 8 Plus)
par John Lobb
No, I talked to iFixit who said it was a faulty battery. They sent a replacement, which had the same problem. While fitting the replacement I damaged my Taptic Engine, and then the replacement I bought for that doesn’t vibrate properly, so I cut my losses and stopped before making the problem even worse and spending even more money. (So now I have a phone that shuts off at 50% battery and with a horrible scratchy vibration like an unhappy floppy drive whenever a haptic event happens.)
par Ed Bennett
@edbennett I DFU restored my phone then restored from backup. Then installed the iOS 16 beta. The result. My battery dies at 10% (rather than 50%) and appears to be getting better with more calibration cycles (100% than 0%). It also charges to 80% then jumps to 100% rather than 50%. I don’t know if the DFU restore or the upgrade to iOS 16 solved the problem. I hope this helps. If it doesn’t resolve itself completely in the next few weeks then I’ll probably replace the battery.
par John Lobb
UPDATE: It didn’t solve anything. After a few weeks the phone reverted back to normal broken cycle. Apologies. I got sent a replacement battery and will attempt to fit that.
par John Lobb
