Aller au contenu principal
Repair guides and support for televisions manufactured by Panasonic.
20 questions Voir tout
We have no picture on our Panasonic TV
Hi, We have no picture on our Panasonic TV (Panasonic TX-65CX700B) Green light flashes quickly, picture appears and the goes dark on the left hand side before the screen goes off completely and we then have a red slow flashing light.
We have carried out suggested reset but still the same problem. Can this be fixed by us at home?
Update (09/26/2021)
Hi, We have tried the test and the colour bars appear clearly but then go off as per our original problem within a few seconds. We did notice the board pictured below clicks even when on standby.
. Thanks, Michala
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Photos added… thank you for the quick reply!
par
Ajouter un commentaire
1 Réponse
Solution retenue
@michala78 anything but the LCD screen is always fixable by anybody. All you need are some basic hand tools and a multimeter to check a few things out. Your TV’s issue sounds like something related to either the power board or the backlight LED’s. Take the back cover off and check all the boards for any obvious damage. Post some good pictures of your boards with your question Ajout d'images à une question existante and include the label identifying your TV. I do suspect that this is an LA59 chassis which will help us to assist you with the repair.
See if you can still do this for your TV:
7.3. LCD Panel test mode
Purpose:
To find the possible failure point where in LCD Panel or Printed Circuit Board when the abnormal picture is displayed.
How to Enter:
While pressing [VOLUME ( - )] button of the main unit, press [YELLOW] button of the remote control three times within 2
seconds.
How to Exit:
Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control.
How to confirm:
If the abnormal picture is displayed, go into LCD Panel test mode to display the several test patterns.
And then, judge by the following method.
Still abnormal picture is displayed: The cause must be in LCD Panel.
Normal picture is displayed: The cause must be in A board.
Remarks:
The test pattern is created by the circuit in LCD Panel.
In LCD Panel test mode, this test pattern is displayed unaffected by signal processing for RF or input signal.
If the normal picture is displayed, LCD Panel must be okay and the cause of failure must be in A board.
Indice 0
1 commentaire:
Same tv same problem did you find out what the fault was?
par
Ajouter une réponse
Michala Harvey sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 1,917
