Kelli Wise could be an issue with the main board or the T-con board. We would need to know what exact model your TV is and what your screen shows. Post some good pictures with your QUESTION. Ajout d'images à une question existante
Since this TV is relatively new I suggest that you contact either the seller or Vizio and have this repaired under current warranty.
Kelli Wise that maybe Sam's own warranty but all Vizio TVs come with a one-year manufacturer’s warranty for non-commercial use or a 90-day warranty period if they are used commercially. If you experience any issue that aligns with Vizio warranty policy, you can file a warranty claim in two ways:
Claiming Vizio TV Warranty via Phone
To file a warranty claim for a Vizio TV over the phone, follow these instructions:
Call (855) 833-3221 or (855) 209-4106
Explain the issue that occurred with your device to the representative and inform them you would like to claim a warranty
Wait for them to give you further instructions regarding sending the faulty product to the repair center
The concern I have is that this maybe a pretty involved repair and since there are no schematics etc. available you would have to try to fix it by replacing complete boards. In the case of your TV I would start with a main board. available used on place like Ebay for around $60 USD. New boards are out of stock at the dealer I commonly buy boards from like Shopjimmy.com. In my experience this means that they are selling fast due to a high failure rate.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
2 commentaires
V505-H1. I contacted Sam's and their warranty is only 3 months. I thought I purchased the extended warranty but apparently not. I uploaded photos to the question. You can hear sound but the picture is those colored lines.
par Kelli Wise
Consumers need to stop spending money on junk. Companies intentionally make products with cheap components so they can increase their profits. Take walks, go hiking, boating, fishing, play games and or any other activity and save your money.
Video controller can cause vertical lines on the screen and if this is the case then it's going to require a service center to make the repair.
par Darren S
