The wire on my Marshall major 2 headphones has frayed on one side help
Hi guys, the wire on my Marshall major headphones has frayed a bit on one side and was causing audio issues until i decided to use a glue (called feviquick) on it with the logic that it will form a protective covering around the wire but instead it made the already feeble connection between them even worse. Now i only get weak sound from one side . Can i fix it myself or should i take it to a repair shop? Btw this happened because of a design flaw in which the earpads are able to rotate completely but the wire is not long enough and so it gets stuck after rotating too much. That kept happening until over time it frayed. Very silly design considering thats its the second iteration of a nice pair of headphones by a good sound company.
