Aller au contenu principal
La 6ème révision d'Apple à la gamme iPod Touch, dévoilée en juillet 2015.
20 questions Voir tout
What is the middle battery connector for?
After Ipod touch battery replacement the battery has been getting stuck at 19% or less
then when it gets low enough the ipod shuts off,
and it take a while to get it to start up again with it plugged in,
Is it possible i got a defective battery?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
14 commentaires
@beanman56 it's possible. where did you get it from?
par
I got my battery from ifixit,
so whats the middle connector for?
par
@beanman56 On the 6 gen I am pretty sure the centre pin is the battery data.
par
Is it needed?
Cus it was ripped off the board
par
@beanman56 Usually one or more pads come off when this happens. How’s you’re soldering skills?
par
Voir 9 commentaires en plus
Ajouter un commentaire
1 Réponse
Solution retenue
Hi
Hope you are well
I did not know really know how to explain this but I had a 6th gen that had the middle battery connection ripped off from previous repair and I noticed that mine would get stuck at 17% and when it would die it straight up wouldn’t charge again but there are test pads above the 3 battery pads and I found the one in the photo had a connection so I ran a jumper and it started working again so hopefully my complex explanation as helped
Anymore questions please ask
Indice 2
10 commentaires:
Whats a jumper
par
@beanman56 A jumper is copper wire that you use when a trace or pad is broken between components. The average size wire is 0.01mm
par
@hellomacos - What size should said jumper be?
par
@beanman56 where you been Sir? Doing ok?
par
Voir 5 commentaires en plus
Ajouter une réponse
Ben Capehart sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 14
Total : 452
