Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sixième génération de la montre connectée d'Apple, avec connectivité cellulaire en option, commercialisée le 18 septembre 2020. Modèle A2376, 44 mm.
How bad is this? (back glass cracked, sensors seem intact)
I just discovered this X-shaped scratch/crack on the back plate of my series 6 watch. I don’t have apple care + (kicking myself for it). The watch seems to be working/charging absolutely normally. I am guessing this breaks the water resistance. Is there anything else that could be a problem? If I take it in for repair, is it just a question of replacing the back plate or will they have to install new sensors?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
As long as it’s still fully functional, I wouldn’t be too worried about that scratch. Apple has never claimed that their devices are waterproof, and suggests the use of the “water lock” feature when doing things that will get your watch wet. As it comes to repair, it’s going to be extremely difficult to replace that. If you take it to Apple, they will probably try to sell you a new device. As long as you’re not too worried about the scratch causing water damage, it shouldn’t be too big of a deal.
Indice 1
Oddly enough, I have the same crack on the same watch. I was debating using some epoxy or glue to fill the crack and try to use it while swimming. I haven't noticed any issues with the functionality even after showering with the crack.
Indice 0
Ajouter une réponse
Anandaroop Ghosh sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 63
Total : 7,637
