Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Dymo LabelManager 160 est rapide, compacte et légère, ce qui facilite l'étiquetage de tout ce que vous voulez, où que vous soyez. Saisissez rapidement du texte sur le clavier QWERTY de type ordinateur, modifiez vos étiquettes grâce aux touches de formatage rapide et imprimez des étiquettes parfaites et professionnelles à chaque utilisation.
Why can't I change the font size over 12
why can’t i change my font size pass 12
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
To enable changing the Font size selection to either 8, 10, 12, 16, 20, or 24, remove and re-insert the Batteries, which enables you change the variable Font settings. Use the Menu button to select one of 3 tape sizes: 1/4, 3/8, or 1/2 inch. The various Font sizes are dependent on the Tape sizes.
par
Ajouter un commentaire
2 Réponses
Solution retenue
@jeanlouisk52448 @stevenburrows for the labelmanager 160 do a complete reset. That should restore your font options.
Turn the printer off
important - REMOVE THE TAPE from the printer
Now press and hold "Backspace" button the "9" and the "On/Off" button at the same time
You may need to try this a couple of times due to the awkwardness of pushing those buttons or try the ERASE option by
REMOVE THE TAPE from the printer. then press "9" and "Backspace" simultaneously, THEN the Power button.
Indice 3
4 commentaires:
I did a complete reset including removing the tape. This time the tape options came up on the screen (they didn't on the first install). I chose 12mm and voila, I have the full set of font sizes. Thanks
par
@stevenburrows great. It seems like the reset needs more than one attempt due to its awkwardness :-)
par
Thank you for this explanation. I was losing my mind trying to figure out why I couldn't get a bigger font than 12. All fixed. :)
par
thank you, helpful though its awkward pressing those buttons that far from each other
par
how do I change fonts
Indice 0
Ajouter une réponse
jean-louis kippelen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 40
30 derniers jours : 144
Total : 5,038
