Why does my iPod nano lose battery so quick?
I charge my nano until it's fully charged but it runs out of battery about 2 hours later.
It does sound like your battery is ready to be replaced. Follow this guide to show you how to get to the battery. It is a bit of a PITA due to the size of the Nano. Of course, before you take it apart, you could also give this a try. the battery is available at places like this. I hope this helps, good luck.
thanks 4 the info but the thing is i just got it about a week ago. Could it b something else?
Not really, you could check on your settings and make sure that your EQ is off etc. You might also try another charger, anything is possible. If you just recently got it, any chance you got some sort of warranty?
thanks sooo much
Maybe Its cause since it is so tiny that the battery should be tiny to so that means a little bit of battery
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 8,158
4 commentaires
My 4 gen ipod mini dies so fast when it's fully charge as I remove of the charger to go low battery what should I do?
par nekojenjen1988
I got a 6th gen nano and when its fully charged I will unplug it, but it literally dies in 5 seconds.
par Alexis
I have this problem as well ... it's a new Ipod Nano, I charge it fully, I play it, and it dies in less than 2 hours.
par antronus10
you need to replace your battery. it does require soldering.
par Crystal Haugh
