Aller au contenu principal
Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
Questions au sujet de 24 Voir tout
Replacement for Flip out USB
Hi there, my Flip Mino HD has a damaged ribbon cable for the USB on the camcorder, I can no longer charge it without the usb. If I can fix the ribbon cable how would I do that, If I need to buy the part where can I buy it from? All help would be appreciated.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
You need to find out how many wires are in it than order a roll of flat ribbon cable from Amazon.
https://www.amazon.com/s?k=flat+ribbon+c...
Indice 1
9 commentaires:
I can’t find the right one and the cable is physically attached to the flip out usb of the camcorder.
par
@TechVid How many wires is in the ribbon?
par
Alao a picture of that connection will help but it's probably just soldered. The wire can be split apart and soldered into place.
par
It is a flat flex cable and I am not sure how to do micro soldering nor do I own a soldering iron
par
Is it true that I can cut the rest of the cable, scratch a little bit of the torn side of the cable until the connectors are showing on both sides of the torn cable and tape them together with both sides touching? Also thanks for not telling me to get a new camcorder, the camcorder is special to me.
par
Voir 4 commentaires en plus
Ajouter une réponse
TechVid sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 44
