Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Model M8541 / 5 or 10 GB hard drive / scroll wheel physically turns
I think my iPod has gone senile
I have a 1st gen classic and when it is plugged in it gives me the file screen. However, when I try putting it in disk mode or debug mode it will freeze up on the apple logo and stay that way untill it either dies or I do a hard reset at which point it will go straight back to the file screen.
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
@zaccpecc could be a hard drive issue. I suggest you go into diagnostics mode and run the checks. Let us know what you find out. For now, my prime suspect is the HDD or the firmware
  • 1st, 2nd, and 3rd Generations
    • Reboot iPod: Hold down the menu and play buttons.
    • Disk Mode: Immediately hold down the rewind and fast forward buttons as the iPod reboots. 1
    • Diagnostic Mode: Hold Rewind, Fast Forward, and Select buttons as the iPod reboots.
    • Non-default Firmware (only when the old ipodloader is installed): Hold Rewind after rebooting the iPod
    • from here
Indice 0
7 commentaires:
I've tried that and it just freezes at the apple logo and goes no further, I've tried a known working hard drive in it and had the same results. I've Eben tried getting into disk and debug mode with the hard drive taken out and had the same results as with it In.
par
Have you tried a complete reset on it?
par
What do you mean by a full reset?
par
Like a restore through iTunes etc.
par
How am i supposed to do that if it won't go into disk mode?
par
Voir 2 commentaires en plus
my 1st gen Ipod has the same problem. It will sometimes go into debug mode or freeze. it will also say the battery is low even if its pluged in. try checking the connection from the hard drive cable to the motherboard ( it's under the click wheel ). do a restore in Itunes/mac os finder. use disk utility/disk management to reformat and check drive for errors. replace the hard drive cable. find up to a 20 gig 3rd gen hard drive ( you could flash mod it too ). if none of this works replace the motherboard.
Indice 0
Ajouter une réponse
Zach peck sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 14
Total : 348
