Aller au contenu principal
Introduite en 2016 lors du lancement de la Xbox One S, la manette Xbox One ajoute le support Bluetooth pour Windows 10. C'est la manette grand public actuellement vendue par Microsoft. Elle rectifie un nombre de défauts de conception des manettes modèles 1537/1697 et elle est beaucoup plus fiable.
20 questions Voir tout
Solder pads came off! How do I fix this?
Was replacing the joystick when one of the at happened to come off! The pad is gone I cannot find it and I do not have a replacement or know what else to do!
If anyone knows how to fix this it would be extremely helpful!
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@rileylearns you’ll have to run some jumpers from the points marked by the arrow. Either short one from the Blue mark or long one from the Red marker. Remove the masking carefully with something like an Exacto knife or a scalpel from those points and then solder a jumper wire to it. You don’t have a lot of room for errors left so make sure that you get a good handle on it. Watch your heat and the time you expose your soldering iron to the pads (red rectangle looks like its ready to melt off). Looks like you are running really hot or long time.Your solder pads will melt off. Make sure that you use good flux and a decent soldering station with the right tip.
Indice 3
Ajouter une réponse
Justin sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 28
Total : 1,717
