Did you faced any of this issues? after screen repair.
Common issues:
- The camera seems to be frozen
- Black screen on the back camera
- The camera app is frozen
- Out of sync flash
- Missing options
Close the Camera App
sometimes the camera app on your iPhone does not get loaded properly, which causes the camera black screen problem. In that case, fix the issue by closing the app of the camera forcefully.
Switch the Front or Rear of the Camera
This trick may help you to deal with the black screen problem without going to an iPhone repair workshop.
Switch off the ‘Voice-Over’ Feature
It sounds surprising that the black screen issue is observed when Voice-Over feature is on. You can simply resolve this issue by following some steps. Go to the phone Setting>General>Accessibility and turn off the ‘Voice-Over’ feature. After that, wait for a while and again launch the camera app.
Restart the iPhone
The common way to fix iPhone black screen camera issue is to reset the power cycle of the device by pressing the Power (Wake/Sleep) button of the device for a few seconds.
Update the iOS Version
There are high chances of a black screen issue on the iPhone due to the outdated and unstable version of iOS. To fix the problem by updating the iOS version in the mobile device.
I hope you’ll find it helpful.
Thank you!!!
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
