Hi @realroguelive,
What is the motherboard's board number? (printed on motherboard itself).
To find the schematics for the motherboard sometimes it is easier if you know the motherboard's make and model number and you would need the schematics to find out where the problem is
Bent pins could mean a possible short circuit between pins when the CPU was secured and when the power was applied to the motherboard something was damaged. It could be in the motherboard or even the CPU. Worst case it could be in both places.
Straightening the pins afterwards wouldn't help as the damage has already occurred.
Knowing which pins were bent and which way they were bent i.e. what other pins they maybe were shorting out to, would speed up the fault diagnosis as there would be a reference point so to speak where to begin but the schematics would definitely be needed. Here’s the pinout for a LGA 1150 socket (see p.112) that may help with this. I think that your motherboard CPU socket is a LGA 1150 but maybe I’m wrong.
I wouldn't insert another CPU in case there is board damage and it damages the new CPU now as well.
if the schematics can be found it doesn’t mean that it can be fixed. It may be a problem in the CPU socket for instance but you won’t know until you know where the problem is.
If you can’t read schematics you will either have to try a computer repair service who do board level repairs or invest in a new motherboard
Just my take on the problem.
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
