Aller au contenu principal
L'Apple iPhone 5s fut annoncé le 10 septembre 2013. La réparation de ce modèle est très similaire aux modèles précédents et requiert des tournevis ainsi que des outils pour faire levier. Disponible en version GSM ou CDMA, 16/32/64 Go de stockage et en argent, doré ou gris sidéral.
32 questions Voir tout
Battery charging but not increasing after replacement new battery
Hello there,
I found quite a bit of info about this issue but I can’t figure out what is the cause.
Many posts talk about the FL11 being damaged when disconnecting the battery causing issues with Gas Gauge Capability.
Unfortunately I don’t have anything else to take photo of the pins with, but from what I could tell it should still be there. I downloaded iBackUpBot to confirm and it shows gas gouge as true as you can see in the screenshot.
I bought new charging cable to rule out it’s not an issue, I tried charging it with my USB port on a laptop, I tried using charger from my old HTC with the new cable with no results.
I tried resetting my settings, and finally I put the phone through DFU, still same issue. I don’t know what else should I try. If there are any people who could help it would be greatly appreciated.
Thank you.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
UPDATE
Went to see a repair shop and they said it’s not the charging chip or the battery, couldn’t say what was wrong only that ultimately it’s an old phone and not worth repairing. They did say it’s probably bcs of use of aftermarket charging cable.
And so my 5S died when I put a new battery in, strange. Oh well, new phone coming, android this time, bye bye Apple!
par
Ajouter un commentaire
1 Réponse
Solution retenue
Sounds like the so called fake charging caused the well known U2 IC, that may get damaged when using aftermarket cables. Unless you live in country with very very low labor costs, a preowned 5S would cost you less than a board repair.
Indice 2
1 commentaire:
thank you for your answer, well this is great, first apple makes low quality cables that break at the end, and then make it so other charges don't work.
I'm officially done with Apple, never buying anything from then again, can't even change a battery.
Thanks again for taking time to reply.
par
Ajouter une réponse
Samwise Thebravee sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 61
