Fixing the actual Chili Pad
Just spent $300+ dollars to replace my pad because it started leaking after I washed it. Now I have a pad to play with and try to repair it. Assuming you can find the right medical grade tubing, this should be an easy fix.
I have suggested to the Chili people that they come up with a patch kit for the older or out of warranty pads. The answer I got back was “we are thinking about it”. Which sort of says… thanks for your suggestion; however, we are in the business of making money for our investors.
Question: I need place to buy the medical grade tubing. Any suggestions?
I will then need to figure out how to attach it to the tubing so it doesn’t leak. Any suggestions?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Jim Puzar let's see what's going on with your pad. Post some good pictures of where and what is leaking. That way we can see what you see. Ajout d'images à une question existante
You have to edit your QUESTION to add images. It'll help us to help you.
par
Ajouter un commentaire
