Aller au contenu principal
7.2 megapixels, 3x optical zoom, 2.5 inch LCD screen, released in August 2006
Questions au sujet de 5 Voir tout
Camera Shows "Lens Error"
The camera powers on, and briefly shows an image on the LCD display. Then eventually it gives a "Lens Error" message.
Has anybody gotten this error before? Know how to fix it, I'm thinking that since the camera shows an image on the LCD, it may be a software rather than hardware problem.
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
3 commentaires
what error no. does it give?
par
pollytintop, I think it's one of those cameras that just says "Lens Error". Usual cause is sand grid and grime in the rings, a dislodged lens, or faulty lens motor. :-)
par
Any way to fix it?
par
Ajouter un commentaire
1 Réponse
Solution retenue
If the lens does not extend/retract properly, then you most likely have something stuck in the zoom gears. If the lens extends but you hear a high pitched buzzing noise, it is the focus motor that is the gears are out or your have debris it it. I would start by reading these tips and see what you get. Also take a quick look at this video to see what you might be up against :-) hope this helps, good luck
Indice 2
Ajouter une réponse
Danny Arenales sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 13,219
