Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
JVC HR-D721EN black image only sound
hello, from uruguay
I have two vhs jvc version HR-D721EN and both play with sound but black image, I already cleaned the heads and it's still the same, if I fast-forward there you can see the rain but then it's black with the play logo. any idea how to repair it or a circuit that is wrong.
here a picture
thanks
spanish:
tengo dos VHS jvc HR-d721EN, y ambos cuando pongo un casette a reproducir solamente se oye el sonido con la imagen en negro y cartel de play, ya le limpie los cabezales y sigue igual, bloquea la imágen
si le reproduzco y adelanto ahí si se ve la lluvia como que quiere verse pero luego vuelve a negro, alguna idea de algo que este mal para reemplazar
gracias
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
In all likelihood it a dirty Video Heads problem. Did you use a 'Wet' type Head cleaning cassette?
Indice 2
2 commentaires:
Yes, I already cleaned the heads and it continues the same
par
How did you clean the Heads? Did you use a Wet Cleaning Cassete, or a Dry Cassette?
Sometimes Cleaning Cassettes are not very succesful in removing the dirt on the video heads. The head has to be Manually cleaned, using a chamois leather cloth and iso-propyl alcohol.,
par
Ajouter une réponse
maricelada sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 31
Total : 342
