Why is my integrated amp going into Standby mode?
My Yamaha A - S301 integrated amp powers up and goes immediately into Standby mode. I already checked the impedance switch on the back of the unit. I also disconnected the speakers to see if they are the culprit, but the problem persists.
4 commentaires
I have the sama problem with my yamaha AS 301. It is randomly turn to standby mode.
Have you solved your problem? How?
Please share your infos.
Thanks
par pempek
Pempek - I did "solve" my problem, but I'm afraid it may not be of much help to you. The repair shop couldn't fix it (luckily they didn't charge me for trying), so I brought it home and started shopping for a replacement. Lo and behold, I gave it one more try and everything has been fine for the last 5 months. It fixed itself I guess.
par Dan Wassink
@dwassink
Shutting off, unplugging and dicharging all power can force most modern electronic device to reset to some degree.
par mike
Dan Wassink - Good to hear your have 'solved' the problem. I still try to isolate the problem. Thanks
par pempek
