Aller au contenu principal
Apple's March 2019 refresh of its iPad Air tablet, sporting an A12 Bionic processor and a 10.5" screen.
20 questions Voir tout
Can someone identify this cable inside ipad air 3?
I am trying to do a screen/lcd replacement on my ipad air 3. I though I did it all correctly and it powers up with perfect screen, but won't respond to touch. I noticed I am missing a cable right next to the battery which is highlighted in green in the attached photo. Can anyone identify what that is?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
thanks so much! So that cable shouldn't affect touch screen? I have no use for sim, so I should be able to use without it?
par
Ajouter un commentaire
2 Réponses
Solution retenue
hello Jared,
It is a sim reader flex tape with connector.
The lack of touch functionality is usually related to screen damage during lifting / detaching from housing. Sometimes it's just a badly inserted connector into the port (check it necessarily and don't forget about the battery: the old principle of electronics - start with the battery when disconnecting and ending with connecting). Sometimes, unfortunately, damage is caused by unreflective disconnection of connectors from the motherboard and damage to them area.
Indice 2
4 commentaires:
par
yes, you right
par
Do you if it will function with an e-sim despite the connector being broken?
par
Is there not a short flex at the bottom with about 4 solder points that needs transferring? Can cause issues if it's not soldered onto the new screen.
Indice 0
1 commentaire:
what you write about is a magnetic sensor for smart cover / keyboard. Causes the screen to turn off when the flap falls on the screen. The tablet will work without it, but yes, it is good practice to move it to a new screen.
par
Ajouter une réponse
Jared Cantor sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 114
