Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le LG 60LM6450 est un téléviseur LED de 60 pouces sorti en 2012. Il prend en charge la vidéo 3D avec des lunettes, avec une résolution de 1920x1080 pixels.
Why is my screen not black but sound works properly
Tv sound is working as should, but screen is black, if I leave tv on with black screen for a few days it will gradually begin turning a reddish color with black spots all over, but only in blotches, whole screen has never fully turned this reddish color. If I turn off tv for a few minutes screen will black out all over again. Also, if I hold a blow dryer toward the black TV screen for a certain period of time that area will begin slowly turning this reddish color I've mentioned. Can y'all help me out with this or do I need to throw the piece of junk away?
Répondre à cette question J'ai le même problème
Indice 2
4 commentaires:
Can you take the back off the TV and upload a picture of the circuit boards inside the TV? Ajout d'images à une question existante
par Partager
It could either be that the screen itself is damaged, or the motherboard has a damaged component. Although I'd like to see an image of the device before I can make that call.
par Partager
Maybe it's a backlight issue. My LG 2015 55" Smart TV worked until 2021 when the backlight stopped working but the sound was fine. If it is a backlight issue, it is fixable, but with a risk of electric shock. What I did is bought a new Vizio TV
par Partager
possibly an issue with the tcon board.
par Partager
Ajouter un commentaire
1 Réponse
What you should do is take the back off, power up the tv then using the hair dryer point it at the boards (one at a time) until the screen shows a picture. When you find it, unplug the tv and take note of the board's part # (taking pictures helps a lot). With this info you can now find a replacement board on ebay or amazon to replace it. Removing and installing a new board is not difficult at all, its more challenging to find the issue and its replacement. You may want to double check to make sure that you really found the problem before ordering a new one!
Indice 0
1 commentaire:
Never touch, change or unplug a board with any power applied!!!
par Partager
Ajouter une réponse
helterskelter7717 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 11
Total : 474
