To start with, is the water on top of the display or under it? My guess is behind it from your description, but I just wanted to make sure.
You are most likely able to have the TV working as normal again. :D
If the water is on top of the screen, take a dry cloth and gently use it to get rid of the water.
If the water is behind the screen, please add a picture of it so that someone with more experience to be able to help you with a solution for how to solve that.
Ajout d'images à une question existante
In the future, avoid using something wet like water or any other chemical/alcohol for cleaning a screen.
Most times, you are good just using a dry microfibre cloth to gently remove most of the dust etc. from the screen.
If there is something eg. sticky, it will probably don't be enough and you may use a slightly DAMP (water) cloth, or some dedicated screen cleaner (spray it on the cloth, NOT directly on the screen).
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
