Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le LG V60 ThinQ 5G, couramment appelé LG V60, est une phablette Android fabriquée par LG Electronics dans le cadre de la série LG V. Il a été annoncé en février 2020 et succède au LG V50 ThinQ. Le 5 avril 2021, LG a annoncé la fermeture de sa division de téléphonie mobile et l'arrêt de la production de tous les appareils restants. LG a précisé que le téléphone resterait disponible jusqu'à épuisement des stocks existants.
Replace LG V60 swollen battery
Is it possible that I can replace the battery myself in an LG V60 ThinQ 5G?
Répondu ! Afficher la réponse J'ai le même problème
Indice 7
3 commentaires
Chargeng problem
par
My phone charging is too slow
=== Update (08/03/25) ===
My phone is too slow charging
par
par
Ajouter un commentaire
3 Réponses
Solution retenue
RAYMOND A BYRNES JR yes you can. Just follow something like this video A bit of patience and the right tools will make all the difference.
Indice 2
3 commentaires:
this video is way to involved to just replace a battery
par
@rayharmacinski You may be right on this one. I'm not sure I see why the motherboard and charging board needed to be removed on this video. I found a similar guide for the V40 ThinQ that just shows the antenna plate coming off then the battery being removed. You'll have to use your best judgement as to whether this same technique will work the same for your V60 though.
https://www.nadiemellamagallina.com/en/m...
If you do end up figuring it out, you can always help others who come along with the same problem by creating your own guide to this repair.
https://www.ifixit.com/Guide/new
par
@rayharmacinski you are absolutely right. That video is for a complete teardown. You only go as far as you need to, in order to remove the battery.
par
how to fix
Indice 0
Show all mobile phones open
Indice 0
1 commentaire:
This may be an issue with translation, but your question isn't answerable as it is. Open can mean either disassembled with a cover removed, or, as I've found, can often simply mean it's turned on.
Either way, it's just not possible to show you ALL possible mobile phones either with the cover or screen off, or what they look like when they're powered up and ready for input.
Please rephrase your question, and if you're using online translation, go ahead and write it in your native language. Regardless, the more information you provide about what you're looking for, the better chance we'll be able to understand it and try to help.
As it stands, if you don't elaborate, we'll eventually just archive your question as unanswerable.
par
Ajouter une réponse
RAYMOND A BYRNES JR sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 33
30 derniers jours : 139
Total : 5,625
