Aller au contenu principal
L'Oculus Quest est le premier casque de réalité virtuelle autonome qui prend en charge le suivi 6DOF avec des caméras situées sur le casque lui-même. Le casque Oculus Quest est sorti en mai 2019 dans des modèles de 64 et 128 Go.
Questions au sujet de 44 Voir tout
How to solder the antenna wire back on the controller motherboard?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
6 commentaires
@nytryder post some pictures of what this all looks like, with your QUESTION. Ajout d'images à une question existante Let's see if we can help you with that.
par
@oldturkey03 Can I send a video of someone taking it apart? https://www.bing.com/videos/search?q=how...
par
@nytryder26 you can post a short video with your QUESTION. It works the same way as posting pictures. Now if you have a longer video, you could post it on places like Youtube etc or place it on Dropbox etc. and we can download it to see what you need help with.
par
@oldturkey03 My camera does not work so I can't, can you look at this youtube video pls?
par
Sure I can. Tell me what I am looking for. Some sort of time stamp....
par
Afficher 1 commentaire en plus
Ajouter un commentaire
1 Réponse
Solution retenue
@nytryder26 okay the antenna cable removal is around 09:00 mins. It is held in place by a small SMD antenna connector. You need to tell us if it is the connector on the board or the one on your cable that has failed. The connector on the board can be changed by resoldering a new one. It' s small so you will need somebody with some micro soldering skills.
If it is the cable there might be a way of splicing a new cable to the old one, or complete replacing it if we can see the other end. You can get replacement at multiple places. Check places like this for more info. Ipex has a variety of the connectors and I believe Digikey.com or Mouser.com has them as well.
Indice 2
3 commentaires:
The plug and the cord ripped off and I tried soldering and it melted the plug.
par
@nytryder26 none of that us ever easy just based on the size of it. The soldering on the board would be relatively easy whereas the wire, I‘d splice it or replace it if you can get to the other end.
par
@oldturkey03 It's super small, I can't solder it. Thanks tho
par
Ajouter une réponse
NR26 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 22
Total : 341
