Aller au contenu principal
Tutoriels de réparation et d'entretien pour un vaste choix d'ustensiles de cuisine.
Questions au sujet de 80 Voir tout
Clean the limescale on the kettle
We have a disc electric kettle at work, we use it for more than a year, there was a scale on the disc, it became unpleasant to drink tea. Just rinse and rinse does not help, what can you clean? I would be glad to hear your suggestions!
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Run vinegar through it (boil it) a time or three this will remove the mineral deposits repeat until you see its all good. The vinegar is acidic and especially heated eats the basic lime away.
Indice 5
6 commentaires:
Agreed. Vinegar makes an excellent calcium/lime deposit remover. OP make sure you let the vinegar sit on the scale build-up so that it has time to work!
par
Brandon is right you can heat it before end of day then leave it soak overnight (off, for safety)
par
You could even use some lemon juice or something as well
par
Anything mildly acidic,. Yes. Coke for example LOL.
par
This also works on shower heads and so on. As Brandon pionted out soaking helps so does agitation. Heat speeds up chemical reactions. A bit of scrubbing once softened helps too.
par
Afficher 1 commentaire en plus
baking soda and boil it 2 times and then do it the 3rd time with plain hot water then tip it out and put fresh water in it and its ready to use again.do that every 3rd week
Indice 1
1 commentaire:
Baking soda is wonderful stuff for removing/controlling odors, will cut grease quite well and lots of other things but its a base, not an acid so this will work to control odors, yes.
par
Buy some citric acid power and put a table spoon to the kettle with water. Boil the kettle and most of the calcium should break off and dissolve. After the kettle has cooled rinse with water and wipe clean. If it has not removed all the limescale just repeat. Citric acid is food safe and natural.
Indice 1
Ajouter une réponse
Lia Hughes sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 152
